I have too many finger print textures that are saved in the artistic texture folder.
I want to access this folder and delete them.
HOW or what folder are they found in on my computer.
Im a little frustrated searching
Hi @reddline,
I’m not sure what you mean with…
This is the directory where you can find the render content textures in Localization folder if that helps.
C:\Users[YOUR NAME]\AppData\Roaming\McNeel\Rhinoceros\6.0\Localization\en-US
When Ive made finger print jewellery. I have added texture, to model on the ring top. I need to remove them from the list.
I have used it in rhino gold 6.
I have rhino 6 that the texture file is full or where I wanted to remove it from.
The Purge command may also help. You can choose what unused information to remove from the file.
