Hello.
There are a lot of building exterior lines and floor number information on the map.
I want to change the layer of the floor number and the layer of the building’s exterior line by detecting the floor number number inside the building exterior line.
You should use the existing layers as they are, and the non-existent layers should be newly created and used. The number of floors in the building is large, so I need help. The number of floors in the building is exactly inside the exterior line.
For example, if the number of floors inside the building’s exterior line is 7, I want to change the layers of the floor number and exterior line to 7 together, and if the number is 15, I want to change the layer to 15.
I hope the color of the newly created layer is random.
Can anyone help me and make it into python code?
