Hello, I’m gonna make an ecommerce configurator that use Arabic input, so I want to add a plugin to Shapediver named “Persian Cat” which let the Arabic letters work in grasshopper.
Thank you in advance!
Thank you for the suggestion, we will evaluate the plugin and let you know if we can support it.
Thanks for replying Mr. Mathieu.
Ok, take your time.
Hello Mr. Mathieu
I hope you’re doing well.
any news about the plug-in evaluation?
We did not have the resources to evaluate this plugin yet, as it seems it is not just a Grasshopper plugin but also a Rhino plugin, and we need to investigate further if it can be safely installed on our servers.
Hello Mr. Mathieu,
Any new please? regarding the plug-in?
Hi Mr. Mathieu,
I hope you are fine.
I’m writing this to remind you of my case you didn’t answer yet
Thank you
I apologize but the plugin you mentioned seems to work in a different way than standard Grasshopper plugins, which means we need to further investigate and potentially be in contact with the developers of the plugin before we can decide to install it on the servers. Unfortunately, we do not have the bandwidth to do this at the moment, so I cannot promise if and when we will support the plugin. I will write again in this topic if the situation changes.
It’s Ok.
So, we’ll try to find another method to do the same function and I hope it will work well
Thanks Mr. Mathieu
