I need help menssage "Please wait while script editor initialize..."
Does anyone know what’s happening?
Does not open the command “Editor Scripty” appears on the screen “Please wait while script editor initializes…”
Hi Edson -
Please start by running the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR25 2022-11-22 (Rhino 7, 7.25.22326.19001, Git hash:master @ 2a680490f96a04550d1f39158b859c4f7739d024)
License type: Commercial, build 2022-11-22
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 15Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 5-22-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 430.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-22-2019
Driver Version: 26.21.14.3086
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\SimLab\Plugins\SimLab Rhino 6 Integration\SimLabComposerIntegration.rhp “SimLab Composer Integration”
C:\Users\edson.souza\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
C:\Users\edson.souza\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Bullant\1.5.11.0\bullant.rhp “bullant” 1.5.11.0
C:\Users\edson.souza\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Users\edson.souza\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\edson.souza\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\FixWindowsToolbar\1.0.0\FixWindowsToolbar.rhp “FixWindowsToolbar” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22326.19001
C:\Users\edson.souza\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.9.1.565\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22326.19001
Thanks,
You have quite a few 3rd party plug-ins installed. Have you tried disabling them and restarting Rhino?
If that doesn’t work, please provide more details on what you do when you get the message.
Are you running a command? Opening a file?
Yes, I installed some third-party plugins to test them, I work on shoe sole projects…
Ok… good idea, I’ll uninstall Rhinoceros 7 and install again!
I will get back to you with result
Thanks a lot for the tip!
Hi -
Just to make sure, I wasn’t suggesting to uninstall and reinstall. That very rarely does anything at all.
You need to disable the plug-ins in the plug-in manager, and for that to kick in, you need to restart Rhino - i.e. exit and launch again.
