Referencing the image with the pink cylinder, the end goal is to thicken the webbing at the top of the cylinder (circled in red) to match the webbing at the center of the cylinder (circled in blue).
In grasshopper, I begin with a cylinder with a bottom, create a bounding box around the cylinder, populate the bounding box with points, create a voronoi within the bounding box, then intersect the voronoi with the original cylinder to get some edges. Then, I create points at the intersections of the edges (green crosses in second image) and ultimately create closed faces to create the image with the red transparent faces. Ultimately, I go onto extruding these faces to create the pink solid shown in the bottom image. However, because the top rim of the cylinder has a width of only one face instead of two, the webbing at the top is not as thick as the webbing in the center.
How can I make this webbing at the top thicker??? I feel like I can do something with the green points, but I’m not sure exactly how!
Thanks in advance for the help!
