I need a bisector in rhinopython
I need a bisector in rhinopython. It can be done?
If you have vectors, you can add them and divide by 2 which will give you the average(bisector)…
It is possible to run the command _Bisector in rhinopython?
If you run it via rs.Command(), yes, I guess so, but you will then need to fill in the screen picks. IMO it’s a lot simpler to create two vectors from your pick points or other geometry and then average them, but YMMV…
Thanks
