I got naked edges i cant remove
I got a building where i need to make the walls solid. BUT it wont let me cz of all the pink lines. But i cant remove them no matter what i try i. It just wont go away
Please provide the rhino file and screenshots of your issue so we can help you
here i can show u
Anti villa 3d.3dm (2.0 MB)
i can se a open edge for the big facing wall but the rest i cant find anything also idk how to fix the big wall
in your fine the wall (all the walls actually) is a closed polysurface, and I do not see any naked edges. what exactly do you wish to achieve?
hold on a second cz when i do i got naked edges as you se in my immage. my goal is to do section drawings but i cant se the hatched lines on the drawings because my walls werent solid let me try smht
idk how cz you got my old version and maybe it was fine by then hmm
how when i enter the same file i have a lot of emptyedges did u select the fasads? and then run the “showedges”
also weird you got that big green field which i dont have anymore
try this file
i think i will just copy the body to the other file damn
OMGGG i solved it lol i just took the file i sent you. idk how you got older version i just copied it from there
