every icon commands was invisible and i don’t know why?? i just updated window 10 for a few weeks and it do well, can anybody help me for this problem?? tkz a lot
Try typing ToolbarReset and see if that helps…
–Mitch
it still not work… :((((( thanks @Helvetosaur
Hmm, OK, so you typed ToolbarReset, Enter, then restarted Rhino and it didn’t help… Dunno, maybe your toolbar file got corrupted.
You can try this:
- Close all instances of Rhino.
- At the start button/start screen, type %appdata%. You should end up
in your AppData folder where you can navigate to:
AppData\Roaming\McNeel\Rhinoceros\5.0\UI
- In that folder you will find some toolbar files including
default.ruianddefault.rui.rui_bak -
Remove the
default .ruifile - Make a COPY of the
default.rui.rui_bakfile - Rename the COPY to
default.rui - Try restarting Rhino…
HTH, --Mitch
Hi Shane,
I see your Rhino is loading a very old version of RhinoRender (sept 12 2013)
What version of Rhino are you running? Do you have the latest SR installed?
https://www.rhino3d.com/download/rhino/5.0/sr
-Willem
Hmm- ToolbarReset should do it - it will unpack a brand new rui file when you restart Rhino. Did you get this sorted out? As Willem points out, you might be a few versions behind, though that should not matter… check for updates and see if that sorts anything out (Help menu).
