I don't see the materials in R8 mac, a black box comes out,
I don’t see the materials in R8 mac, a black box comes out,
Hi Esalazar245,
Please run systeminfo in the rhino command line and post the results.
Can you also post the file of said box as well?? Thanks
te envio el sisteminfo, I sent you the systeminfo, cualquier informacion o configuracion te lo agradezco en R7 para mac no ocurre, y R9 si se ve los iconos, y pude depurar los materiales no cargados adecuadamente
Any information or configuration I appreciate it in R7 for mac does not happen, and R9 if you see the icons, and I was able to debug the materials not loaded properly
en windows no ocurre eso, That doesn’t happen on Windows,
(attachments)
BANCO HORIZONTAL.3dm (5.47 MB)
(attachments)
sisteminfo mac studio M2.txt (5.34 KB)
Thanks for the file, everything opens up and renders fine in a similar environment.
lets remove these two 3rd party plugins for troubleshooting.
  /Users/edgar/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/DatasmithRhino8.rhp	"Datasmith Exporter"	5.5.1.0
  /Users/edgar/Library/Application Support/McNeel/Rhinoceros/packages/8.0/RhinoBanana/0.1.15-beta.1/RhinoBanana.rhp	"RhinoBanana"	0.1.15.0
Greetings, and I delete or deactivate it by PlunginManager because it had PackageManager and now in the command line it does not appear
saludos, y lo borro o desactivo por PlunginManager porque tenía PackageManager y ahora en la linea de comando no aparece
Already deleted and still the same
ya borrado y sigue igual
(attachments)
I don’t see Datasmith being available on the package manager.
In the command line I no longer see PackageManager but pluginManager (R8 mac…?), but the files you indicated to me are already deleted
Sorry for the delay but we are in an emergency situation in Venezuela
Disculpa la tardanza pero estamos en una situación de emergencia en venezuela
en la linea de comando ya no me aparece PackageManager si no pluginManager (R8 mac…?), pero los archivos que me indicaste ya esta borrados
Ok, if you are 100% sure have cleared out any 3rd party variables, lets run the Reset command and go back to factory settings.
