I don't know how to connect objects to the nods
I have a curve, a plane and an object. How do I connect them?
Hi Artem,
It appears you are looking to create a custom Curtain Wall Panel Family or modify an existing one.
Here is our guide on working with these types of Revit Elements.
If you need more specific help please see this post on providing info that will help us help you. Thanks
Thank you
Вс, 12 янв. 2025 г. в 15:39, Japhy via McNeel Forum <notifications@mcneel.discoursemail.com>:
I can’t set up the code for these panels. The line is not displayed as panels. And then how do I set up the offset? and different panel lengths?
(attachments)
I also created this in revita. But I can’t, how can I move on to create automation of panels?
(attachments)
Not quite following what you are trying to do.
Here is more information on Rhino.Inside.Revits capabilities in regard to Curtain Walls.
https://www.rhino3d.com/inside/revit/1.0/guides/revit-curtainwalls
automation. And when the panel was increased, it was possible to calculate the estimate
вс, 12 янв. 2025 г. в 18:58, Japhy via McNeel Forum <notifications@mcneel.discoursemail.com>:
The System Curtain Panel Family has an Area Parameter
