I chose a wrong template for measurements. How can I change it to the right one? :P
I stated using Rhino only recently. I got my design finished but then I realised I had chosen wrong template!! I had used centimetres when I was supposed to use millimetres. Really annoying mistake. :confounded: Can I save my design somehow or do I have to start all over again on a different template?
Just go to Settings>units and change from cm to mm. When it asks you if you want to scale the model, answer no.
Your units should now be mm.
HTH, --Mitch
Thanks a million for the advice. I got it sorted. :grinning:
