I can't use a few commands in rhino8 (Evaluation)
When i type command such as Make2D , Isolate . It always shows Unknown Command.How can i fix it?thanks
fe
Hi -
Could you please post a screenshot of the Rhino Options -> Plug-ins dialog where the filter is set to Utility Plug-ins? Like this:
Where is Utility Plug-ins?I can’t find it.
Hi -
You are missing quite a few entries in that list, yes.
I’m unable to find an evaluation license for Rhino 8 connected to your email address here, where did you download Rhino?
I use another email how can i sent you the information?
Really?
Back to the future… :stuck_out_tongue_winking_eye:
I actually downloaded it from Rhino evaluation.
I used that 90 days license key
2566 is BE year in my country
Buddhist calendar; I didn’t know that Windows supported non-gregorian calendars. Good for them!
-Jakob
Hi -
Does the SystemInfo command work on your system?
I had no idea, sorry!
Try to type the Command with an underscore infront of the Command like this: _Pan
It works. This is my SystemInfo command.
I tried it but i didn’t work.
Please copy and paste all of the text in the SystemInfo here. There is text that we need to see that is not included in that image.
Sorry
Here is the SystemInfo text
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Evaluation, build 2023-11-21
License details: Cloud Zoo
Expires on: 2024-02-24
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 9-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.34
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-1-2023
Driver Version: 31.0.15.3734
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\Admin\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
For some reason one of the main plugins for Rhino is not running in your installation of Rhino. Did you make any changes with the plugin manager and try to disable plugins?
Probably the best thing to try at this point is to drag and drop
c:\Program Files\Rhino 8\Plug-ins\commands.rhp
On to your Rhino 8 and then restart
Sorry i don’t understand , drag Commands.rhp to Rhino 8 Folder or where ? I found it but i don’t know where to drop it. I didn’t do anything with plugin.
If i drop it in Rhino 8 Viewport, it pops up this error. Thanks for helping.
You did exactly what I asked, thanks. For some reason Rhino is refusing to use that plug-in. Your computer’s clock seems to be really really off based on the file explorer image you show. That may something to try fixing to see if it helps.
