Hi guys
I can’t select object edges and surfaces of my revolved objects, neither fillet them, or anything else.
snaps don’t work, objects are solid, shade mode active, if wireframe mode active I see only one U isocurve.
Ive never had an issue like that, can u help me?
I’m running macOS sierra, the issue appears with both rhino final and rhinoWIP.
thanks,
JuMBo
edit: osnaps and smart track are activated!
I’m wondering if for some reason you have crease splitting turned off and your revolved object is just one kinked surface… What does Properties say about the object? What happens if you select the object and run
DivideAlongCreases SplitAtTangents=Yes SplitAtKinks=Yes
does that help any?
–Mitch
wow thank you.
that helped.
I don’t understand why crease splitting was turned off. this is confusing…
anyway it works now…
OK, call the command CreaseSplitting
and set SplitAlongCreases=Yes
if you haven’t already. Occasionally there is some gremlin in the system that resets this to No, nobody really knows why… --Mitch
done.
thank you very much.
