I can't see visualarq on grasshopper
Hy guys,
I installed last version visualarq 2.0 beta . Every time I open grasshopper on rhino, I can’t see visualarq tools on the menu.
Any suggest?
Hi @Adriana_Caldarone
First, remember that in order to use VisualARQ 2.0 Beta you need to use the “VisualARQ 2.0 Beta” icon you’ll find on your desktop or start menu.
And, VisualARQ Grasshopper Components are only available if VisualARQ is loaded, so if you are not seeing them, run any VisualARQ command (like _vaAbout) or open any VisualARQ document or start a new document using a VisualARQ template.
Regards,
Enric
Yes, I opened rhino by visualarq icon on desktop. The command vaAbout is not recognized by rhino. So, I think it’s an istallation error. I try to reinstall it. Thank you
OK. Let me know if you don’t solve your problem.
Thanks,
Enric
Thank you Enric. I solved the problem by reinstalling visual arq. See you
Adriana
