I can't add it
Yes. The curves have the same point count but the way they are lined up will cause that twisting. Try to line them up:
hah… i write about it and dont see it myself thanks @wim
in this file your curves don’t meet the rules I posted earlier:
-rail curves have identical structure (one is 11 control points, the other 13)
-end points of cross section is on end point (as @encephalon clearly pointed out)
Easiest way to do this is by making one rail, and copy this over, then modifying the control points
