Hi all,
I’ve spent a lot of time on stadium seating work, and the part that always wore me down was the repetition: set up a section, lay out the rows, check the sightlines, change one riser height, then do it all again for the next stand. So I ended up building a tool for it.
Antlion is a Grasshopper plugin for stadium seating bowls. Instead of drawing each stand by hand, you set up the field and a start line, and the sections, rows, vomitories and seats come out of that. C-values are worked out for every seat, so after a change you can see straight away which seats lost their view.
Some of what it does:
- Sections can be drawn by hand, solved from a target C-value, or typed into an Excel / Google Sheets workbook
- Your own Rhino curves can drive the field outline, start line, axes, cuts and seat blocks
- Results go onto drawing sheets and back into the workbook
- Works in millimeter and inch documents
The first part of a tutorial series, building a soccer stadium from scratch:
What I’d really like to know: is anyone here doing stadium seating in practice? How do you handle sightlines today: your own definitions, spreadsheets, something else?
If you’re curious, it installs from the Rhino 8 Package Manager (search “Antlion”; Rhino 8 for Windows). It’s a commercial plugin with a 14-day trial. Details are on the Food4Rhino page: Antlion | Food4Rhino
Even a short try and a couple of lines here would help a lot: what was confusing, what’s missing, where it broke. Docs: Antlion — Stadium Seating and C-value Sightlines for Grasshopper · plugin.dev.lab
Thanks!
Quick update: two or three more tutorial videos are coming over the next week or two, each on a different stadium layout. I’ll post them here as they go up.
The second tutorial is up: a two-tier, multi-purpose indoor arena.
This one keeps the sections in a Google Sheet. You write each tier as a table, bring it into Grasshopper, then adjust vomitories, aisles, wheelchair spaces and seats by hand with Custom Seat. After the 3D build and the C-value check, the results go back to the sheet, so changing a value there updates the whole bowl.
Chapters are in the video description. As before, any feedback is welcome, especially on the sheet workflow.
A shorter one this time: a 4-minute explainer on why some stadium seats can’t see the field.
It’s mostly diagrams rather than Grasshopper screens: what the C-value measures, how the focal point and the shape of the section decide it row by row, why the corners of a bowl need their own check, and a few mistakes that keep showing up. The last part shows how Antlion handles this.
Subtitles are available in 12 languages. Feedback is welcome, especially if any part of the explanation is unclear or off.
The third tutorial is up: a track and field stadium, with the stands around a 400 m running track.
This one keeps the sections in an Excel workbook. You redraw the axes by hand with Custom Axis, draw your own vomitories for Custom Seat, and join a second, VIP section to the main bowl. After the 3D build and the C-value check, the results go back to Excel.
That completes the tutorials I mentioned earlier in the thread. Chapters are in the video description, and subtitles are available in 12 languages. Feedback is welcome, especially on the Excel and VIP section steps.
Two updates since the last post, both from user requests:
Field (1.0.20) - the focal point can now sit in from the field edge and above it at the same time. Focal Direction Mode and Focal Offset are replaced by two numbers, Focal Horizontal and Focal Vertical. With both at 0 the focal point stays on the field edge, as before.
Stand (1.0.23) - Auto Section and Section have a new input, Riser Thickness, right below Slab Thickness, so the slab under the treads and the riser legs can each have their own thickness, as in precast stadia. The top surface doesn’t move, so sightlines and C-values stay the same, and Stand 3D Plus follows the new profile. With a workbook, both values come from the workbook.
Older files open with the new inputs. Grasshopper may show an “IO generated N messages” window the first time; it is safe to close. Update through the Package Manager. The full list of changes is in the changelog: Antlion changelog · plugin.dev.lab
If you work with section details that Antlion can’t describe yet, I’d like to hear about them.
A new video, for anyone just getting started with Antlion: a map of where things are.
It starts on the Food4Rhino page, then tours the Antlion website (getting started, the workflow, the component pages, tutorials and troubleshooting) and the new help cards inside Grasshopper: how to open one, how to follow the chain from Field, and how to fold it away. Near the end it shows where to check what changed if a tutorial doesn’t match your screen.
Subtitles are available in 12 languages. Feedback is welcome, especially if something is still hard to find.
