Hi everyone,
I’ve been experimenting with connecting AI to the Tekla Open API.
The idea was pretty simple: sometimes describing a change takes one sentence, but actually making it means going through filters, selections and property dialogs. I wanted to see how much of that I could do just by typing to chat what I need.
Things like:
“Replace all HEA200 columns on grid C with HEA240.”
“Find and select all RHS* profiles.”
“Set class 3 and prefix B for all beams in phase 2.”
The plugin interprets the request and uses the Open API to make the changes. For bigger changes, it shows a preview and waits for me to press Run.
I called it TeklaAIBridge (you can find it on YouTube). What started as a chat experiment gradually grew into a small toolbox: applying naming standards across a model, reading column schedules and grid plans from images, setting connection parameters, and generating canopy layouts with grids.|
I’m curious what other Tekla users think. What repetitive task would you most like to handle with a sentence instead of a series of clicks?
More details and a way to try it: https://teklaaibridge.com
