I asked ChatGPT to solve Sweep1 in gh
update: tested on both closed and open rails
import Rhino.Geometry as rg
# Inputs:
# rail      : Curve
# profiles  : list of Curves
# segments  : Integer
# Outputs:
# breps
# report
breps = []
report = ""
tol = 0.001
angle_tol = 0.01
def profile_center(crv):
    return crv.GetBoundingBox(True).Center
def make_sweep():
    sw = rg.SweepOneRail()
    sw.SweepTolerance = tol
    sw.AngleToleranceRadians = angle_tol
    sw.ClosedSweep = False
    return sw
if not rail:
    report = "No rail."
elif not profiles:
    report = "No profiles."
else:
    rail_crv = rail.DuplicateCurve()
    valid_profiles = [p for p in profiles if p and isinstance(p, rg.Curve)]
    if not valid_profiles:
        report = "No valid profiles."
    else:
        sweep = make_sweep()
        # CASE 1: OPEN RAIL + ONE PROFILE
        if len(valid_profiles) == 1 and not rail_crv.IsClosed:
            base_profile = valid_profiles[0]
            rc, base_t = rail_crv.ClosestPoint(profile_center(base_profile))
            if not rc:
                report = "Could not find profile position on rail."
            else:
                rc_base, base_plane = rail_crv.PerpendicularFrameAt(base_t)
                rc0, plane0 = rail_crv.PerpendicularFrameAt(rail_crv.Domain.T0)
                rc1, plane1 = rail_crv.PerpendicularFrameAt(rail_crv.Domain.T1)
                if not rc_base or not rc0 or not rc1:
                    report = "Could not get rail frames."
                else:
                    p0 = base_profile.DuplicateCurve()
                    p1 = base_profile.DuplicateCurve()
                    p0.Transform(rg.Transform.PlaneToPlane(base_plane, plane0))
                    p1.Transform(rg.Transform.PlaneToPlane(base_plane, plane1))
                    result = sweep.PerformSweep(rail_crv, [p0, p1])
                    if result:
                        breps = list(result)
                        report = "Created full open sweep from one profile."
                    else:
                        report = "Open sweep failed."
        # CASE 2: CLOSED RAIL + ONE PROFILE
        elif len(valid_profiles) == 1 and rail_crv.IsClosed:
            if not segments or segments < 3:
                segments = 24
            if rc:
                rail_crv.ChangeClosedCurveSeam(base_t)
                params = rail_crv.DivideByCount(segments, False)
                params = list(params) if params else []
                params.insert(0, rail_crv.Domain.T0)
                params.append(rail_crv.Domain.T1)
                rc, base_plane = rail_crv.PerpendicularFrameAt(params[0])
                temp_breps = []
                if rc:
                    for i in range(len(params) - 1):
                        t0 = params[i]
                        t1 = params[i + 1]
                        seg = rail_crv.Trim(t0, t1)
                        if not seg:
                            continue
                        rc0, plane0 = rail_crv.PerpendicularFrameAt(t0)
                        rc1, plane1 = rail_crv.PerpendicularFrameAt(t1)
                        if not rc0 or not rc1:
                            continue
                        result = sweep.PerformSweep(seg, [p0, p1])
                        if result:
                            temp_breps.extend(list(result))
                if temp_breps:
                    joined = rg.Brep.JoinBreps(temp_breps, tol)
                    breps = list(joined) if joined else temp_breps
                    report = "Created closed sweep from one profile."
                else:
                    report = "Closed sweep failed."
        # CASE 3: MULTIPLE PROFILES
        else:
            profile_data = []
            for p in valid_profiles:
                rc, t = rail_crv.ClosestPoint(profile_center(p))
                if rc:
                    profile_data.append((t, p))
            profile_data.sort(key=lambda x: x[0])
            if len(profile_data) < 2:
                report = "Need at least 2 valid profiles."
            else:
                temp_breps = []
                for i in range(len(profile_data) - 1):
                    t0, p0 = profile_data[i]
                    t1, p1 = profile_data[i + 1]
                    if not seg:
                        continue
                    if result:
                if rail_crv.IsClosed:
                    t0, p0 = profile_data[-1]
                    t1, p1 = profile_data[0]
                    rail_loop = rail_crv.DuplicateCurve()
                    rail_loop.ChangeClosedCurveSeam(t0)
                    rc, new_t1 = rail_loop.ClosestPoint(profile_center(p1))
                    if rc:
                        seg = rail_loop.Trim(rail_loop.Domain.T0, new_t1)
                        if seg:
                            if result:
                if temp_breps:
                    report = "Created sweep from multiple profiles."
                else:
                    report = "Sweep failed."
Hi @Bogdan_Chipara,
You might tell ChatGPT that the SweepOneRail class has been has been superseded by the Brep.CreateFromSweep static functions.
Specifically, use Brep.CreateFromSweepSegmented unless you want to refit the rail curve, in which case you’d use Brep.CreateFromSweep.
– Dale
Hi @dale !
Yes, it uses sweep.PerformSweep
Have you tried adjusting the script with ChatGPT? You can copy-paste what I have and try your instructions.
It should work on closed rails, open rails, one profile several profiles.
note:
instead of:
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.sweeponerail
use:
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.brep/createfromsweepsegmented
