The component offsets a number of curves at a specified distance on a surface and extends them up till surface boundary. This is done recursively, each curve is created based on the previous one. This is very advantageous when solving corner details.
In this example i use another custom component that creates a network surface based on 2 input curves.
OffsetExtendRecu:
import Rhino
def get_first_curve(offset_result):
if not offset_result:
return None
for crv in offset_result:
if crv is not None:
return crv
return None
def extend_curve_on_surface(crv, surface):
if crv is None:
return None
brep_face = surface.ToBrep().Faces[0]
extended = crv.ExtendOnSurface(
Rhino.Geometry.CurveEnd.Both,
brep_face
if extended:
return extended
return crv
def recursive_offsets(curve, surface, distance, offsetsno, tolerance):
left_curves = []
right_curves = []
# LEFT SIDE
current = curve
for i in range(offsetsno):
result = Rhino.Geometry.Curve.OffsetOnSurface(
current,
surface,
-distance,
tolerance
current = get_first_curve(result)
if current is None:
break
current = extend_curve_on_surface(
current,
surface
left_curves.append(current)
left_curves.reverse()
# RIGHT SIDE
current = curve
current,
surface,
distance,
tolerance
if current is None:
break
current,
surface
right_curves.append(current)
return left_curves + [curve.DuplicateCurve()] + right_curves
# Inputs:
# curve
# surface
# distance
# offsetsno
# tolerance
a = recursive_offsets(
curve,
surface,
distance,
int(offsetsno),
tolerance
NetSrf2Crvs:
import Rhino.Geometry as rg
import System
from System import Int32
from clr import StrongBox
# Inputs:
# A : list of curves
# B : list of curves
# N : divisions
# Outputs:
# S : surfaces
# L : connector curves
# E : errors
S = []
L = []
E = []
N = max(1, int(N))
count = min(len(A), len(B))
for i in range(count):
crvA = A[i]
crvB = B[i]
if not crvA or not crvB:
continue
a = crvA.DuplicateCurve()
b = crvB.DuplicateCurve()
a.Domain = rg.Interval(0, 1)
b.Domain = rg.Interval(0, 1)
curves = [a, b]
# create connector curves
for j in range(N + 1):
t = float(j) / float(N)
ptA = a.PointAt(t)
ptB = b.PointAt(t)
line = rg.Line(ptA, ptB).ToNurbsCurve()
curves.append(line)
L.append(line)
curve_array = System.Array[rg.Curve](curves)
error = StrongBox[Int32]()
srf = rg.NurbsSurface.CreateNetworkSurface(
curve_array,
1, # continuity
0.01, # edge tolerance
0.01, # interior tolerance
0.01, # angle tolerance
error
E.append(error.Value)
if srf:
S.append(srf)
layercake facade recursive.gh (88.0 KB)
