I asked ChatGPT for SubSrf input in Grasshopper
Sometimes is just so much useful to directly input subsurfaces into grasshopper.
In the video I take subsurfaces of a polysurface and add different hatches to them.
And this is the code for the component:
# input subsurfaces. use buttons for pick and clear
# Inputs:
#   pick  : Button
#   clear : Button
# Output:
#   A     : picked subsurfaces as Breps
import Rhino
import Rhino.DocObjects as rd
import scriptcontext as sc
import Grasshopper
comp = ghenv.Component
ghdoc = comp.OnPingDocument()
# Persistent state per component instance
key = "SubSrfPicker_" + str(comp.InstanceGuid)
state = sc.sticky.get(key)
if state is None:
    state = {
        "refs": [],              # list of (Guid, face_index)
        "pick_was_down": False,
        "clear_was_down": False,
        "subscribed": False,
        "scheduled": False
    sc.sticky[key] = state
# Helper: schedule ONE recompute safely
def schedule_recompute():
    st = sc.sticky.get(key)
    if st is None:
        return
    if st.get("scheduled", False):
        return
    st["scheduled"] = True
    sc.sticky[key] = st
    if doc is None:
        st["scheduled"] = False
        sc.sticky[key] = st
        return
    def cb(d):
        st2 = sc.sticky.get(key)
        if st2 is not None:
            st2["scheduled"] = False
            sc.sticky[key] = st2
        comp.ExpireSolution(False)
    doc.ScheduleSolution(10, cb)
# Rhino doc event handlers
def on_replace(sender, e):
    if st is None:
        return
    watched_ids = set([obj_id for obj_id, fi in st["refs"]])
    if e.ObjectId in watched_ids:
def on_delete(sender, e):
    if st is None:
        return
def on_undelete(sender, e):
    if st is None:
        return
# Subscribe once per component instance
if not state.get("subscribed", False):
    Rhino.RhinoDoc.ReplaceRhinoObject += on_replace
    Rhino.RhinoDoc.DeleteRhinoObject += on_delete
    Rhino.RhinoDoc.UndeleteRhinoObject += on_undelete
    state["subscribed"] = True
# Clear logic
# If one or more stored subsurfaces are currently selected in Rhino,
# remove only those.
# If none are selected, clear all.
# Rising-edge detect on clear button
if clear and not state.get("clear_was_down", False):
    state["clear_was_down"] = True
    refs_to_remove = []
    for obj_id, face_index in state["refs"]:
        rh_obj = Rhino.RhinoDoc.ActiveDoc.Objects.FindId(obj_id)
        if rh_obj is None:
            continue
        ci = Rhino.Geometry.ComponentIndex(
            Rhino.Geometry.ComponentIndexType.BrepFace,
            face_index
        if rh_obj.IsSubObjectSelected(ci):
            refs_to_remove.append((obj_id, face_index))
    if refs_to_remove:
        remove_set = set(refs_to_remove)
        state["refs"] = [r for r in state["refs"] if r not in remove_set]
    else:
        state["refs"] = []
elif not clear and state.get("clear_was_down", False):
    state["clear_was_down"] = False
# Async picker callback
# Runs after the GH solution finishes
def launch_picker(doc):
    go = Rhino.Input.Custom.GetObject()
    go.SetCommandPrompt("Select Brep/Extrusion face(s)")
    go.SubObjectSelect = True
    go.GeometryFilter = rd.ObjectType.Surface
    go.GetMultiple(1, 0)
    picked_refs = []
    if go.CommandResult() == Rhino.Commands.Result.Success:
        for i in range(go.ObjectCount):
            objref = go.Object(i)
            if objref is None:
                continue
            face = objref.Face()
            if face is None:
                continue
            picked_refs.append((objref.ObjectId, face.FaceIndex))
    st = sc.sticky.get(key, {
        "refs": [],
        "subscribed": True,
        "scheduled": False
    existing = set(st["refs"])
    for ref in picked_refs:
        if ref not in existing:
            st["refs"].append(ref)
            existing.add(ref)
    st["pick_was_down"] = False
    sc.sticky[key] = st
# Rising-edge detect on pick input
# Use a Button, not a Toggle
if pick and not state["pick_was_down"]:
    state["pick_was_down"] = True
    if ghdoc is not None:
        ghdoc.ScheduleSolution(1, launch_picker)
elif not pick and state["pick_was_down"]:
    state["pick_was_down"] = False
# Resolve stored refs into standalone face Breps
# Supports Breps and Extrusions
out = []
    if rh_obj is None:
        continue
    geom = rh_obj.Geometry
    brep = None
    if isinstance(geom, Rhino.Geometry.Brep):
        brep = geom
    elif isinstance(geom, Rhino.Geometry.Extrusion):
        brep = geom.ToBrep()
    if brep is None:
        continue
    if 0 <= face_index < brep.Faces.Count:
        face_brep = brep.Faces[face_index].DuplicateFace(False)
        if face_brep is not None:
            out.append(face_brep)
A = out
