I asked ChatGPT for a voxelization tool
This tool is particularly useful for creating closed 3D printable meshes from one or several open meshes.
I made it using ChatGPT and it took a couple of hours of optimizing and testing.
It can be used as an alternative to ShrinkWrap.
Initial input, open mesh:
Voxel size = 5mm
Total computing time = 3.56 sec
Voxel size = 1mm
Total computing time = 41.51 sec
Voxel size = 0.5mm
Total computing time = 203.36 sec
# VOXEL TOOL V3
import Rhino
import scriptcontext as sc
import System
import math
import time
from concurrent.futures import ThreadPoolExecutor
from System.Collections.Generic import List
# SETTINGS
DEFAULT_VOXEL_SIZE = 100.0
WORKERS = 5
# Sampling spacing relative to voxel size.
# 0.50 = reliable
SAMPLE_FACTOR = 0.50
# Number of voxel expansion layers
DILATION_STEPS = 1
# Bounding-box padding
PADDING_VOXELS = 2
# INPUT
def get_mesh_ids():
    ids = rs.SelectedObjects()
    if ids:
        result = []
        for obj_id in ids:
            obj = sc.doc.Objects.FindId(obj_id)
            if (
                obj and
                isinstance(
                    obj.Geometry,
                    Rhino.Geometry.Mesh
                result.append(obj_id)
        if result:
            return result
    return rs.GetObjects(
        "Select meshes to voxelize",
        rs.filter.mesh,
        preselect=True
# COMBINE INPUT MESHES
def combine_meshes(ids):
    combined = Rhino.Geometry.Mesh()
    for obj_id in ids:
        if not obj:
            continue
        mesh = obj.Geometry
        if not isinstance(
            mesh,
            Rhino.Geometry.Mesh
            continue
        combined.Append(mesh)
    combined.Vertices.CullUnused()
    # Temporary triangulation only.
    # Original Rhino meshes are untouched.
    combined.Faces.ConvertQuadsToTriangles()
    combined.Compact()
    return combined
# VOXEL INTEGER KEYS
def voxel_key(i, j, k, nx, ny):
    return i + nx * (j + ny * k)
# EXTRACT TRIANGLES
def extract_triangles(mesh):
    vertices = mesh.Vertices
    triangles = []
    append = triangles.append
    for index in range(mesh.Faces.Count):
        f = mesh.Faces[index]
        a = vertices[f.A]
        b = vertices[f.B]
        c = vertices[f.C]
        append(
                float(a.X),
                float(a.Y),
                float(a.Z),
                float(b.X),
                float(b.Y),
                float(b.Z),
                float(c.X),
                float(c.Y),
                float(c.Z)
    return triangles
# TRIANGLE RASTERIZER
def rasterize_chunk(
    triangles,
    voxel_size,
    xmin,
    ymin,
    zmin,
    nx,
    ny,
    nz
    occupied = set()
    add_voxel = occupied.add
    sample_spacing = (
        voxel_size *
        SAMPLE_FACTOR
    inv_voxel = 1.0 / voxel_size
    for tri in triangles:
        ax = tri[0]
        ay = tri[1]
        az = tri[2]
        bx = tri[3]
        by = tri[4]
        bz = tri[5]
        cx = tri[6]
        cy = tri[7]
        cz = tri[8]
        # EDGE VECTORS
        abx = bx - ax
        aby = by - ay
        abz = bz - az
        acx = cx - ax
        acy = cy - ay
        acz = cz - az
        bcx = cx - bx
        bcy = cy - by
        bcz = cz - bz
        # EDGE LENGTHS
        lab = math.sqrt(
            abx * abx +
            aby * aby +
            abz * abz
        lac = math.sqrt(
            acx * acx +
            acy * acy +
            acz * acz
        lbc = math.sqrt(
            bcx * bcx +
            bcy * bcy +
            bcz * bcz
        longest = max(
            lab,
            lac,
            lbc
        divisions = max(
            1,
            int(
                math.ceil(
                    longest /
                    sample_spacing
        inv_div = 1.0 / divisions
        # BARYCENTRIC SAMPLING
        for ui in range(divisions + 1):
            u = ui * inv_div
            remaining = divisions - ui
            for vi in range(remaining + 1):
                v = vi * inv_div
                w = 1.0 - u - v
                x = (
                    w * ax +
                    u * bx +
                    v * cx
                y = (
                    w * ay +
                    u * by +
                    v * cy
                z = (
                    w * az +
                    u * bz +
                    v * cz
                i = int(
                    math.floor(
                        (x - xmin) *
                        inv_voxel
                j = int(
                    math.floor(
                        (y - ymin) *
                        inv_voxel
                k = int(
                    math.floor(
                        (z - zmin) *
                        inv_voxel
                if (
                    0 <= i < nx and
                    0 <= j < ny and
                    0 <= k < nz
                    add_voxel(
                        i +
                        nx *
                            j +
                            ny * k
    return occupied
# MULTITHREADED TRIANGLE RASTERIZATION
def rasterize_triangles(
    triangles,
    voxel_size,
    xmin,
    ymin,
    zmin,
    nx,
    ny,
    nz
    count = len(triangles)
    worker_count = min(
        WORKERS,
        count
    if worker_count < 1:
        return set()
    chunk_size = int(
        math.ceil(
            float(count) /
            worker_count
    chunks = []
    for start in range(
        0,
        count,
        chunk_size
        chunks.append(
            triangles[
                start:
                start + chunk_size
    print("")
    print(
        "Rasterizing with {} workers...".format(
            len(chunks)
    occupied = set()
    with ThreadPoolExecutor(
        max_workers=worker_count
    ) as executor:
        futures = []
        for chunk in chunks:
            futures.append(
                executor.submit(
                    rasterize_chunk,
                    chunk,
                    voxel_size,
                    xmin,
                    ymin,
                    zmin,
                    nx,
                    ny,
                    nz
        for index, future in enumerate(futures):
            result = future.result()
            occupied.update(result)
            print(
                "Worker {} / {} complete   "
                "surface voxels: {:,}".format(
                    index + 1,
                    len(futures),
                    len(occupied)
    return occupied
# FAST 6-NEIGHBOUR DILATION
def dilate_voxels(
    occupied,
    nx,
    ny,
    nz,
    steps
    if steps <= 0:
        return occupied
    print("")
    print(
        "Expanding voxel shell by {} layer(s)...".format(
            steps
    current = occupied
    layer = nx * ny
    for step in range(steps):
        expanded = set(current)
        add = expanded.add
        for key in current:
            k = key // layer
            rem = key - k * layer
            j = rem // nx
            i = rem - j * nx
            if i > 0:
                add(key - 1)
            if i < nx - 1:
                add(key + 1)
            if j > 0:
                add(key - nx)
            if j < ny - 1:
                add(key + nx)
            if k > 0:
                add(key - layer)
            if k < nz - 1:
                add(key + layer)
        current = expanded
        print(
            "  layer {}: {:,} voxels".format(
                step + 1,
                len(current)
    return current
# OPTIMIZED OUTPUT MESH
# Main improvements:
# - final mesh vertex indices are assigned DURING boundary scan
# - no used_vertices set
# - no second vertex-map construction
# - faces already contain final mesh vertex indices
# - Point3f instead of Point3d
# - bulk AddVertices()
# - bulk AddFaces()
def build_voxel_mesh_fast(
    occupied,
    xmin,
    ymin,
    zmin,
    voxel_size,
    nx,
    ny,
    nz
    print("")
    print("Building optimized boundary mesh...")
    total_start = time.time()
    # Grid vertex dimensions
    gvx = nx + 1
    gvy = ny + 1
    gv_layer = gvx * gvy
    voxel_layer = nx * ny
    # GRID VERTEX KEY -> FINAL MESH INDEX
    vertex_map = {}
    # Store only the grid keys in final vertex-index order.
    vertex_keys = []
    vertex_append = vertex_keys.append
    # Faces already reference final mesh indices.
    face_indices = []
    face_append = face_indices.append
    contains = occupied.__contains__
    get_existing = vertex_map.get
    # FAST VERTEX INDEX CREATION
    def get_vertex_index(ix, iy, iz):
        grid_key = (
            ix +
            gvx *
                iy +
                gvy * iz
        existing = get_existing(grid_key)
        if existing is not None:
            return existing
        index = len(vertex_keys)
        vertex_map[grid_key] = index
        vertex_append(grid_key)
        return index
    # SINGLE BOUNDARY SCAN
    boundary_start = time.time()
    for key in occupied:
        k = key // voxel_layer
        rem = key - k * voxel_layer
        j = rem // nx
        i = rem - j * nx
        # -X
        if (
            i == 0 or
            not contains(key - 1)
            a = get_vertex_index(
                i,
                j,
                k
            b = get_vertex_index(
                i,
                j,
                k + 1
            c = get_vertex_index(
                i,
                j + 1,
                k + 1
            d = get_vertex_index(
                i,
                j + 1,
                k
            face_append(
                (a, b, c, d)
        # +X
        if (
            i == nx - 1 or
            not contains(key + 1)
                i + 1,
                j,
                k
                i + 1,
                j + 1,
                k
                i + 1,
                j + 1,
                k + 1
                i + 1,
                j,
                k + 1
            face_append(
                (a, b, c, d)
        # -Y
        if (
            j == 0 or
            not contains(key - nx)
                i,
                j,
                k
                i + 1,
                j,
                k
                i + 1,
                j,
                k + 1
                i,
                j,
                k + 1
            face_append(
                (a, b, c, d)
        # +Y
        if (
            j == ny - 1 or
            not contains(key + nx)
                i,
                j + 1,
                k
                i,
                j + 1,
                k + 1
                i + 1,
                j + 1,
                k + 1
                i + 1,
                j + 1,
                k
            face_append(
                (a, b, c, d)
        # -Z
        if (
            k == 0 or
            not contains(
                key - voxel_layer
                i,
                j,
                k
                i,
                j + 1,
                k
                i + 1,
                j + 1,
                k
                i + 1,
                j,
                k
            face_append(
                (a, b, c, d)
        # +Z
        if (
            k == nz - 1 or
            not contains(
                key + voxel_layer
                i,
                j,
                k + 1
                i + 1,
                j,
                k + 1
                i + 1,
                j + 1,
                k + 1
                i,
                j + 1,
                k + 1
            face_append(
                (a, b, c, d)
    boundary_time = (
        time.time() -
        boundary_start
    print(
        "Boundary scan   : {:.2f} sec".format(
            boundary_time
    print(
        "Vertices        : {:,}".format(
            len(vertex_keys)
    print(
        "Exposed faces   : {:,}".format(
            len(face_indices)
    # vertex_map no longer needed
    vertex_map = None
    # CREATE Point3f ARRAY
    print("")
    print("Preparing compact vertex array...")
    vertex_start = time.time()
    points = List[
        Rhino.Geometry.Point3f
    points.Capacity = len(
        vertex_keys
    point_add = points.Add
    # Cache locals
    sx = float(voxel_size)
    ox = float(xmin)
    oy = float(ymin)
    oz = float(zmin)
    # Decode grid keys directly
    for key in vertex_keys:
        iz = key // gv_layer
        rem = key - iz * gv_layer
        iy = rem // gvx
        ix = rem - iy * gvx
        point_add(
            Rhino.Geometry.Point3f(
                float(
                    ox +
                    ix * sx
                float(
                    oy +
                    iy * sx
                float(
                    oz +
                    iz * sx
    vertex_keys = None
    vertex_time = (
        time.time() -
        vertex_start
    print(
        "Vertex array    : {:.2f} sec".format(
            vertex_time
    # CREATE MeshFace ARRAY
    print("")
    print("Preparing face array...")
    face_start = time.time()
    mesh_faces = List[
        Rhino.Geometry.MeshFace
    mesh_faces.Capacity = len(
        face_indices
    face_add = mesh_faces.Add
    for a, b, c, d in face_indices:
        face_add(
            Rhino.Geometry.MeshFace(
                a,
                b,
                c,
                d
    face_indices = None
    face_time = (
        time.time() -
        face_start
    print(
        "Face array      : {:.2f} sec".format(
            face_time
    # BULK CREATE RHINO MESH
    print("")
    print("Creating Rhino mesh...")
    rhino_start = time.time()
    result = Rhino.Geometry.Mesh()
    result.Vertices.Capacity = (
        points.Count
    result.Faces.Capacity = (
        mesh_faces.Count
    result.Vertices.AddVertices(
        points
    result.Faces.AddFaces(
        mesh_faces
    points = None
    mesh_faces = None
    result.FaceNormals.ComputeFaceNormals()
    result.Normals.ComputeNormals()
    result.Compact()
    rhino_time = (
        time.time() -
        rhino_start
    print(
        "Rhino mesh      : {:.2f} sec".format(
            rhino_time
    print(
        "Output building : {:.2f} sec".format(
            time.time() -
            total_start
    return result
# MAIN
def main():
    ids = get_mesh_ids()
    if not ids:
        return
    voxel_size = rs.GetReal(
        "VoxelSize",
        DEFAULT_VOXEL_SIZE,
        0.000001
    if voxel_size is None:
        return
    start_time = time.time()
    old_redraw = rs.EnableRedraw(False)
    try:
        print("")
        print("FAST VOXEL RASTERIZER")
        print("=====================")
        print(
            "Meshes      : {}".format(
                len(ids)
        print(
            "VoxelSize   : {}".format(
                voxel_size
        print(
            "Workers     : {}".format(
                WORKERS
        print(
            "Sample step : {:.3f}".format(
                voxel_size *
                SAMPLE_FACTOR
        # COMBINE
        print("")
        print("Combining meshes...")
        mesh = combine_meshes(
            ids
        if mesh.Faces.Count == 0:
            print(
                "No valid mesh faces."
            return
        print(
            "Triangles: {:,}".format(
                mesh.Faces.Count
        # BOUNDING BOX
        bbox = mesh.GetBoundingBox(
            True
        padding = (
            voxel_size *
            PADDING_VOXELS
        xmin = (
            bbox.Min.X -
            padding
        ymin = (
            bbox.Min.Y -
            padding
        zmin = (
            bbox.Min.Z -
            padding
        xmax = (
            bbox.Max.X +
            padding
        ymax = (
            bbox.Max.Y +
            padding
        zmax = (
            bbox.Max.Z +
            padding
        nx = max(
            1,
            int(
                math.ceil(
                        xmax -
                        xmin
                    voxel_size
        ny = max(
            1,
            int(
                math.ceil(
                        ymax -
                        ymin
                    voxel_size
        nz = max(
            1,
            int(
                math.ceil(
                        zmax -
                        zmin
                    voxel_size
        print("")
        print(
            "Grid: {} x {} x {}".format(
                nx,
                ny,
                nz
        print(
            "Full grid would contain {:,} voxels".format(
                nx *
                ny *
                nz
        # EXTRACT TRIANGLES
        print("")
        print(
            "Extracting triangle coordinates..."
        triangles = extract_triangles(
            mesh
        mesh = None
        # RASTERIZATION
        surface_voxels = rasterize_triangles(
            triangles,
            voxel_size,
            xmin,
            ymin,
            zmin,
            nx,
            ny,
            nz
        triangles = None
        print("")
        print(
            "Initial surface voxels: {:,}".format(
                len(
                    surface_voxels
        if not surface_voxels:
            print(
                "No voxels generated."
            return
        # DILATION
        occupied = dilate_voxels(
            surface_voxels,
            nx,
            ny,
            nz,
            DILATION_STEPS
        surface_voxels = None
        occupied_count = len(
            occupied
        print("")
        print(
            "Final occupied voxels: {:,}".format(
                occupied_count
        # OUTPUT
        output = build_voxel_mesh_fast(
            occupied,
            xmin,
            ymin,
            zmin,
            voxel_size,
            nx,
            ny,
            nz
        occupied = None
        # ADD TO RHINO
        print("")
        print(
            "Adding result to Rhino..."
        result_id = sc.doc.Objects.AddMesh(
            output
        if (
            result_id ==
            System.Guid.Empty
            print(
                "Could not add output mesh."
            return
        elapsed = (
            time.time() -
            start_time
        # REPORT
        print("")
        print("DONE")
        print("====")
        print(
            "Occupied voxels : {:,}".format(
                occupied_count
        print(
                output.Vertices.Count
        print(
            "Faces           : {:,}".format(
                output.Faces.Count
        print(
            "Closed          : {}".format(
                output.IsClosed
        print(
            "Valid           : {}".format(
                output.IsValid
        print(
            "TOTAL TIME      : {:.2f} sec".format(
                elapsed
    finally:
        rs.EnableRedraw(
            old_redraw
        sc.doc.Views.Redraw()
if __name__ == "__main__":
    main()
