sonam
(sonam )
November 14, 2024, 10:02am
1
I am stuck here and not able to move further.
ftzuk
(Ftzuk)
November 14, 2024, 10:04am
2
Upload code. Can’t work from a jpeg.
(admin please hurry with the jpeg > gh converter)
Hello
Look at this discussion if it could help
Hello
welcome to this forum. What you asked is a very classical question, if you invest some time learning the basics of the tool you will surely manage to do it.
here are some guides for this forum
In order to make this pattern you need some stars (polar array of a line). Points can be used from this tool
[image]
In order to thicken it the most simple thing is to use Clipper plugin, 2 or 3 plugins are available on Food4rhino. I use this one
You must provide 3 lines in the same branch …
Ans as advised above “Upload code” and read this
Asking questions and getting answers is what this forum is all about. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions, but don’t think of them as rules and especially don’t think of them as guarantees.
1. Choose a descriptive title for your post
Don’t title your question Help! or I have a problem or Deadline tonight!, but actually describe the problem you are having.
2. Be s…
It is an offset that you need.
First deconstruct each triangle, cut each segment at a given ratio (0.5 for middle)
Shift the list of 6 segment
Then partition this list every 2 segments,
Make the new triangles by adding 2 lines going to the center.
Then join.
Then use an attractor to calculate the offset value you want
trapezium_LD.gh (16.5 KB)
sonam
(sonam )
November 14, 2024, 10:56am
6
Thank you for your help! This is really amazing.
