I am trying to create a Planter with a outer cladding of 300mm intervals
I managed to capture the verticle surfaces of the planter, but i need to have a 300 interval lines across the outside of the planter. is there any suggestions?
No idea what you want - maybe draw a picture? Also no code attached.
code for cladding.gh (6.8 KB)
here is the code, I want to create lines across the planter to maintain a 300 mm distance between the the lines
Need to internalize data. Also you will either need to have an area that’s less than 300mm or you must have divisions slightly more or less than 300mm. You can’t divide an arbitrary shape into equal 300 sections all around.
