Hard time trying to implement export via Backend API.
Always getting internal error.
Need help.
Thanks in advance.
Need help.
Thanks in advance.
Could you provide a code example as well as the ticket and/or URL of the model you are trying to trigger exports from?
I am doing a simple post request via POSTMAN.
Now, its saying “backend access not allowed”. Even though its allowed in the Shapediver UI.
The ticket shown in your screenshot is a different one than the one you mentioned before. Is it a wrong one?
Could it be that for some reason your Postman is sending an Origin
header?
Can be, I am not sure.
I tried cURL from terminal, its working.
But the export request is throwing empty response.
Please check, likely that’s the issue.
What is the request payload you are sending? Please add details which allow to fully reproduce the problem.
