Hyperlink has a problem with the most recent Rhino update
The problem seems to be it doesn’t understand [SPACE] anymore, as I tried to manually type the location after copy and paste brings up Unknown Command.
This what we use with Hyperlink all day here so we can quickly open the folder and it’s stopped working:
Z:\Design\Clients working files\S\Smith, Duncan 25123\
Hi - for urls or directory paths that contain a space character, you will need to put that string between two quotes. If not, the parser will take the space as Enter and will then try to parse the remaining string as commands.
So this works here:
  • Select an object
  • Run Hyperlink
  • Select the Attach option
  • Paste the following string:
“Z:\Design\Clients working files\S\Smith, Duncan 25123”
