Hybrid workflow: Eddy 3D+Ladybug+Wallacei
Greetings Milad, I have a complex workflow setup that should simulate wind using Eddy 3D and use the output to feed into HB UTCI Comfort map component to measure thermal comfort changes as the design of courtyard is changing. I’m not sure if Wallacei is the best choice because the way I sat up the workflow is any changes in the number sliders (controlling the courtyard dimensions) does not reflect immediately on an outcome. It takes time to simulate the wind and then feed it into the HB component. All this is mediated by custom made Python components that handles the timing between Eddy 3D and HB. I have tried naively to connect the sliders and the objective functions to Wallacei but it does not start at all and simply shows immediately a message saying simulation finished.
I would appreciate your kind help
PassiveHouse_Rhino.gh - Copy.3dm (481.7 KB)
PssiveHouse_GH_113.gh (628.7 KB)
Hi Nora,
There are currently some compatibility issues between Eddy and Wallacei. I need a bit more time to investigate this further and we should coordinate with Eddy. Butterfly on the other hand, works smoother with Wallacei
