I’m trying to bake lines out of grasshopper to specific layers with a specific color. Every two lines will receive the same color and be on the same layer. When I try to do this in Human, it does not bake properly and neither does lunchbox. Attached are the problem images with Human. Images below.
problem1 shows the issue. So I have 125 data branches with two elements, each branch will receive one color and be baked. Human does not do this–it bakes the first 5 lines then freaks out.
problem2 shows what the resulting lines should look like. Notice that the first 5 red lines were properly baked, but it doesn’t do the other 120 lines. I’ve done this before on Rhino 5, but work computers are Rhino 6 now, so I’m not sure what’s wrong
problem3 shows the component happy, but the colors are wack. I flattened the stream of lines coming in and it baked.
Any ideas what could be wrong?
problem1
problem2
problem3
