I’m trying to use the Hull Assistant with Orca to create a 7.7m RIB that is developable. The RIB I want is not really fitting the RIB template, and it’s being made from aluminium so I need to make plates from it.
Using the DevHullAssistant seems to give a good starting point for what I want but the scaling is huge (40m to transom) I tried scaling all values down but sections just vanish and the model looks broken. What is the best solution to this? Are there other templates I can download for this as a starting point?
