I have a file that takes forever to open and save, it is around 700 MB but contains a few curves.
I tried to save small, Purge, copy the curves and paste in a new document. Still 700 MB.
I then used -SaveSmall and set “no” to SaveTexture and SavePlugInData and “Yes” to SaveSmall and GeometryOnly.
The file went to 255 Ko.
Why would Plug-in data or textures be attached to curves?
Before the -SaveAs, a curve’s Detailed properties would look like this:
curve
Object name: xxxxxxxxxxxxL
Layer name: Make2D::Visible
Render Material:
source = from layer
index = -1
Attribute UserData:
UserData ID: B63ED079-CF67-416c-800D-22023AE1BE21
Plug-in: Renderer Development Kit
description: RDK data
saved in file: yes
copy count: 9709
Going back to an older version, I tried all the options of -SaveAs separately. The only one that had a significant effect on file size is “GeometryOnly”.
