Https://www.visualarq.com/2019/02/22/parametric-truss-with-a-beam-grasshopper-style/
Hi. Can you please share with the community your grasshopper file ? Thanks so much ! Daniel
Hi Daniel, Sure.
Find it attached.Regular Height Truss.gh (33.6 KB)
Important: this definition uses beam styles from VisualARQ-meters template so I recommend to open it using a VisualARQ-Meters template.
You may need also to re-select the beam styles from the lists:
Thanks Francesc !
Thank you so much, indeed.
