dsw
November 21, 2017, 1:30pm
#1
I’m searching for an example code to create arrows like from the gumball which can be moved and and where i can react on the changes during or after the movement.
For example like in rhinogold where you can drag and move a circle to change the position and the diameter (e.g. in the video https://www.youtube.com/watch?v=ISX3dRaZpnI starting at 3:20)
I also made a screenshot and marked the arrows and points which i want to create by my own.
dale
(Dale Fugier)
November 27, 2017, 7:50pm
#3
Hi @dsw ,
There is a RhinoCommon sample that demonstrates how to manipulate geometry with a gumball.
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinocommon/cs/SampleCsCommands/SampleCsGumballCylinder.cs
If you need something in C++ or you need a different sample, let me know.
– Dale
dsw
November 28, 2017, 2:35pm
#4
Hi @dale
Thank you for the sample. I think it’s exactly what i wanted. Unfortunately i could not translate everything correctly to c++. i got some weird result.
It would be helpful if you got a simple example how to deal with two ore more gumballs in C++.
Thanks
dale
(Dale Fugier)
November 29, 2017, 7:37pm
#5
dsw
November 30, 2017, 7:07am
#6
Hi @dale
i made now a short c++ sample by converting your C# sample. It’s not yet fully functional, but it shows my problem with the picking of the gumball. I cannot pick the correct axis, in my case it’s always the y-rotation in perspective view and in the other views i cannot pick at all.
I’m pretty sure there is something wrong with the picking context, but referring to the c++ sample from you ( http://developer.rhino3d.com/guides/cpp/picking-objects-without-crhinogetobject/ ) it should work.
Can you please have a look at this code?
Thanks
ON_Plane gPlane;
double gRadius = 1.0;
double gHeight = 2.0;
class SampleCsGumballCylinderGetPoint : public CRhinoGetPoint
CRhinoGumballDisplayConduit* m_height_dc;
ON_3dPoint m_base_origin;
ON_3dPoint m_base_point;
public:
SampleCsGumballCylinderGetPoint(CRhinoGumballDisplayConduit* heightDc)
m_height_dc = heightDc;
m_base_origin = ON_3dPoint::UnsetPoint;
m_base_point = ON_3dPoint::UnsetPoint;
virtual void OnMouseDown(CRhinoViewport& vp, UINT nFlags, const ON_3dPoint& point, const CPoint* view_wnd_point)
if (m_height_dc->m_pick_result.m_gumball_mode != GUMBALL_MODE::gb_mode_nothing)
return;
m_height_dc->m_pick_result.SetToDefaultPickResult();
CRhinoPickContext pick_context;
pick_context.m_view = vp.ParentView();
pick_context.m_pick_style = CRhinoPickContext::point_pick;
switch (vp.DisplayMode())
case ON::shaded_display:
case ON::renderpreview_display:
pick_context.m_pick_mode = CRhinoPickContext::shaded_pick;
break;
vp.GetPickXform(view_wnd_point->x, view_wnd_point->y, pick_context.m_model_xform);
vp.VP().GetFrustumLine(view_wnd_point->x, view_wnd_point->y, pick_context.m_pick_line);
pick_context.UpdateClippingPlanes();
// try picking one of the gumballs
if (m_height_dc->PickGumball(pick_context, this))
m_base_origin = gPlane.Origin();
m_base_point = point;
virtual void OnMouseMove(CRhinoViewport& vp, UINT nFlags, const ON_3dPoint& point, const CPoint* view_wnd_point)
if (m_base_origin.IsValid() && m_base_point.IsValid())
ON_Line world_line;
if (vp.VP().GetFrustumLine(view_wnd_point->x, view_wnd_point->y, world_line))
ON_3dVector dir = point - m_base_point;
double len = dir.Length();
if (m_base_origin.DistanceTo(point) < m_base_origin.DistanceTo(m_base_point))
len = -len;
// update hight gumball
m_height_dc->UpdateGumball(point, world_line);
// update cylinder
gHeight = len;
CRhinoGetPoint::OnMouseMove(vp, nFlags, point, view_wnd_point);
virtual void DynamicDraw(HDC dc, CRhinoViewport& vp, const ON_3dPoint& point)
ON_Cylinder cyl;
cyl.Create(ON_Circle(gPlane, gRadius), gHeight);
vp.DrawCylinder(cyl);
// Disable default GetPoint drawing by not calling the base class
// implementation. All aspects of gumball display are handled by
// GumballDisplayConduit
//base.OnDynamicDraw(e);
CRhinoGet::result MoveGumball()
return this->GetPoint(nullptr, true);
CRhinoCommand::result SampleCommand::RunCommand( const CRhinoCommandContext& context )
CRhinoGetPoint gp;
gp.SetCommandPrompt(L"Base of cylinder");
gp.GetPoint();
if (gp.CommandResult() != success)
return gp.CommandResult();
gRadius = 1.0;
gHeight = 2.0;
ON_3dPoint center = gp.Point();
gPlane = ON_Plane::World_xy;
CRhinoView* view = gp.View();
if (nullptr != view)
gPlane = view->ActiveViewport().ConstructionPlane().m_plane;
gPlane.SetOrigin(center);
CRhinoGumball height_go;
CRhinoGumballDisplayConduit height_dc;
while (true)
height_go.SetFromPlane(gPlane);
height_dc.SetBaseGumball(height_go);
height_dc.Enable();
height_dc.EnableGumballDraw(true);
SampleCsGumballCylinderGetPoint gx(&height_dc);
gx.SetCommandPrompt(L"Drag gumball. Press Enter when done");
gx.AcceptNothing(true);
gx.MoveGumball();
//radius_dc.Disable();
height_dc.Disable();
if (gx.CommandResult() != success)
break;
CRhinoGet::result res = gx.Result();
if (res == CRhinoGet::point)
continue;
if (res == CRhinoGet::nothing)
break;
RhinoApp().ActiveDoc()->Redraw(CRhinoView::regenerate_display_hint);
return success;
dale
(Dale Fugier)
December 8, 2017, 11:37pm
#7
Hi @dsw ,
Sorry this took so long. Here is (basically) a port of the C# version.
https://github.com/mcneel/rhino-developer-samples/blob/6/cpp/SampleCommands/cmdSampleGumballCylinder.cpp
I sure wish this were easier…
– Dale
dsw
December 11, 2017, 6:17am
#9
Hi @dale
i tried this code in my project, but unfortunately it does not work because in Rhino 5 i do not have SetClippingRegionTransformation.
And if i calculate the clipping region by the pickcontext itself with UpdateClippingPlanes(), the sample does not work. i can see the preview and the arrows, but i cannot pick and drag them.
Is there a workaround in Rhino 5?
dale
(Dale Fugier)
December 11, 2017, 5:54pm
#10
dsw
December 12, 2017, 7:47am
#11
Hi @dale
thank you very much for your fast support. Everything works perfect!
