How to write script in Python for SetPt Command
I’d like to write script in Python for SetPt Command.
“SetPt” command ( and some other cases ) shows specific option dialog to input, I’d like to set the options from script.
Where can I find these method ?
Hi Katsu,
you could always use a the hyphened version of the command like so:
   rhinoscriptsyntax.Command('_-SetPt ...
it will suppress the dialog and prompt to the commandline instead:
Location for points ( XSet=Yes YSet=Yes ZSet=Yes Alignment=World Copy=No ):
HTH
-Willem
Here is a sample in C#:
https://github.com/dalefugier/SampleCsCommands/blob/master/SampleCsSetPoint.cs
You should be able to translate into Rhino.Python.
Hi Willem
This is simple and easy way.
Thank you very much .
Katsu
Hi dale,
Thank you very much.
I was moved by your code.
I found SetPt command is not a special function, but only a transform…
