Is there a straightforward way to find all available Export Schemes for dxf/dwg?
It seems no longer stored in the registry, or I’m searching in the wrong place.
Thanks
-Willem
Thanks
-Willem
I seem to recall reading here that R6 doesn’t use the registry any more, but instead stores the info in app data. Not at the Rhino machine right now so can’t check or confirm actual location.
Hi @Willem,
All settings and preference, in Rhino 6, are stored in XML files found here:
%APPDATA%\McNeel\Rhinoceros\6.0\settings
Note, only non-default values are stored.
Does this help?
– Dale
Thanks, Dale!
I think I’ll manage from here.
-Willem
Hi @dale
Reviving this topic as I only now came to implementing the check.
I found that the acadschemes are not stored in the settings files in
after some digging I found they are stored in the plugin folder
%AppData%\McNeel\Rhinoceros\6.0\Plug-ins\AutoCAD file export export_ACAD (39a88493-9e97-4f15-bd62-ad25896a2632)\settings
Wanted to let this know for future visitors looking for the settings.
-Willem
