I need to create a numerous amount of cylinders in my project, is there an easier way to keep using the cylinder tool instead of having to type in the command every time I need to create a single cylinder?
Normally, a right mouse click or hit Enter after the command is finished will repeat it. You can continue to make as many cylinders as you want one at a time this way.
It is also possible to set up a macro with *_Cylinder
which will repeat automatically without having to hit Enter between.
Thank you so much!
