Hi all,
I have a question.
I can use the the flow with stretch condition in Rhino.
I want to edit a grasshopper and also can use flow with stretch condition.
Unfortunately. Grasshopper only have base and target condition can be select.
But I didn’t find any place where I can set the stretch condition. as below image shown.
I don’t see how flow with stretch would deform the cube into a tapered shape, that seems to make little sense to me. I suspect you will need FlowAlongSrf for this, or a box transform. What is your goal eventually?
Hi Gijs,
Sorry to confuse you. Let me explain in detail.
I want to fillet more than 10000 cubes at the same time.
I tried using flow and FlowAlongSrf, but the result is not what I want.
If you want to fillet the boxes like indicated, I’d make them a bit taller so that the fillet doesn’t end at the bottom, then cut them afterward to the correct height.
If you need further help pls share the gh file
