I want to use Rhino to get the color out of a picture frame for a list of sample points on another layer.
Which object should I use to achieve this?
I read this and I don’t think that can apply to RhinoCommon
I do not think there is specific image handling inside RhinoCommon, however you should have access to
What language are you working in?
-Willem
Hi Willem,
I am using C#, what I want to do a function similar to Heightfield.
I want a picture at the background or as a picture frame first. Then later I can use my own Height field function to draw the height field on another layer.
Toby
Hi Toby,
A picture frame is nothing more than a planar surface with a material that has a bitmap texture.
Does this help?
