I need to batch export detail drawings from layout views to PDF, but I currently don’t have a clear approach. Here is the code I have so far. Can anyone help me with this?@Dale
I hope to use RhinoCommon to automate batch printing of detail views in layouts. As shown in the image, there are three views in total, but with the code below, I can only print the content of view 1 at a time, and I am unable to access views 2 and 3.
Rhino.DocObjects.Tables.ViewTable viewTable = Rhino.RhinoDoc.ActiveDoc.Views;
string dir = "C:\\Users\\jimmy\\Desktop\\";
int dpi = 600;
var pvs = doc.Views.GetPageViews();
foreach (var view in pvs)
var dvs = view.GetDetailViews();
foreach (DetailViewObject detail in dvs)
var pdf = Rhino.FileIO.FilePdf.Create();
view.SetPageAsActive();
view.SetActiveDetail(detail.Id);
int w = Convert.ToInt32(view.PageHeight);
int h = Convert.ToInt32(view.PageWidth);
System.Drawing.Size size = new System.Drawing.Size(Convert.ToInt32(h * 600 / 25.4), Convert.ToInt32(w * 600 / 25.4));
Rhino.Display.ViewCaptureSettings settings = new Rhino.Display.ViewCaptureSettings(view, size, dpi);
settings.RasterMode = false;
double res = settings.Resolution;
pdf.AddPage(settings);
string filePath = System.IO.Path.Combine(dir, detail.Id.ToString() + ".pdf");
pdf.Write(filePath);
return Result.Success;
