I used SolidPtOn in Rhino5 and i found the function called ON_TransformBrepComponents in RhinoCommon SDK which achieve the same result probably.
However, i don’t know how to use this function.
Can someone post a simple example how to use it.Thanks!!!
Hi @wayne387315
You are right. ON_TransformBrepComponents is what SolidPtOn uses. Which part of the function was not clear? Here is the header description
Description:
Transform a list of brep components, bend neighbors
to match, and leave the rest fixed.
Parameters:
brep - [in]
brep to modify
brep_component_count - [in]
Length of brep_components[] array
brep_components - [in]
components to transform.
xform - [in]
transformation to apply to compoents
tolerance - [in]
Desired fitting tolerance to use when bending
faces that share edges with both fixed and
transformed components.
time_limit - [in]
If the deformation is extreme, it can take a long time to
calculate the result. If time_limit > 0, then the value
specifies the maximum amount of time in seconds you want
to spend before giving up.
bUseMultipleThreads - [in]
True if multiple threads can be used.
Returns:
True if successful.
ON_DECL
bool ON_TransformBrepComponents(
ON_Brep* brep,
int brep_component_count,
const ON_COMPONENT_INDEX* brep_components,
ON_Xform xform,
double tolerance,
double time_limit,
bool bUseMultipleThreads
I’ve moved this discussion to the Rhino Developer category because ON_TransformBrepComponents is only implemented on the Rhino SDK (and not standalone openNURBS).
I want to know these two parameter .
First one is int brep_component_count,the description said that
“Length of brep_components[] array”. How can I know the length or
what is the components it mentioned?
Second,const ON_COMPONENT_INDEX* brep_components,I think it is an array,
but I don’t know what I should put into the array.
That refers to the number of brep parts (or components) that you need to transform. For example, if you are transforming 3 vertices in the breps, you pass “3”. This is needed because you are passing a pointer to the array, and hence the size of it is not clear.
Each brep part (Face, Edge, Vertex) has a unique identification called “COMPONENET_INDEX”. You can get to it by calling the ComponentIndex() function.
For example if you compile an array of component indexes that you need to transnfom with something like:
After knowing how to use it , I have already done lots of works by using this function.
I am very curious about how to program the function like this.
Before using this function , I tried many methods to transform a brep.
However, I can’t make it successfully. I am eager to know what is the correct way to transform a brep.
Could you get me the source code or something that I can study for.
Thanks!!
ON_TransformBrepComponents is in opennurbs_brep.h in my SDK.
I have already checked the opennurbs_brep.cpp in GitHub , I still can not find it.
I think the opennurbs_brep.cpp is not complete in GitHub or maybe it’s in other place that I haven’t find yet.
