How to use Elk to extract building heights
unhandled
(Alyssa Parsons) #1
Hey,
I am trying to find the center point of the top of every building through ELK and an osm file. I did the same thing with meerkats and it worked super well. But with ELK I don’t know what to plug the unit Z vector into to find the height of the buildings.
this is what happens when i plug the Z vector into W from the OSM plug-in.
(Wim Dekeyser) #2
You should post your gh file if you want anyone to try to help you.
(Lando Schumpich) #3
There is another output underneath ‘W’ which is called ‘bldg’. It has all the buildings osm git 3d data on as 3d brep. You could go:
‘Bldg’ -> ‘deconstruct Brep’ -> ‘sort (for z)’ -> ‘area’ -> the centroid output af area is your solution.
Be warned though I found many osm data sets lacking in 3d data
