Does anyone have the correct syntax for using the text block dimension command a rhino
marco?
Can prompt the command but not enter txt. Any ideas?
marco?
Hi Peter - what is the exact name of the command you’re working with? If _Text, try:
! _-Text _Pause "Here is some text." _Enter
Hi Pascal,
Thanks for your help. That’s pretty close.
Also need to put in the start point as a part of the string, any ideas?
Regards,
Petter
