How to use a grasshopper to automate command “ _NetworkSrf "?
how to use a grasshopper to automate calling the command “platform according to network curves” ?
I draw along the X and Y axis, then add (slices) lines along the Z axis (they just create volume).
I created an algorithm for myself: I create lines along the X, Y, and Z axes.
They are closed to each other and you can create a plane using a network of curves using the “ _NetworkSrf ” command.
It is this element that I want to automate (blue lines on the model).
Is it possible to do this with the grasshopper tool?
Безымянный.3dm (186.0 KB)
