- Click the Image icon in the toolbar.
- When the upload window the “Drag files here” appears, drag your 3dm file onto the window.
This topic is now pinned. It will appear at the top of its category until it is either unpinned by a moderator, or the Clear Pin button is pressed.
Discourse now supports file uploads in addition to image uploads; it is up to the admins to enable this option and set the file extensions that are allowed:
adamcon 7 speech.txt(42.7 KB)
If money doesnt make you happy then you probably arent spending it right.pdf(470.8 KB)
Here are two sample files, uploaded via the “upload” button in the composer. (The tooltip for it still says ‘image’ unfortunately, we will fix that, but give it a shot!)
