How to update or modify RenderMaterial in C#?
I attempted to convert DisplayMaterial to RenderMaterial and assign it to a layer. However, I’m unsure how to update existing RenderMaterial properties (such as texturepath,Diffuse,..) in C#. Below is the relevant code snippet:
Could you advise on the correct approach for this?
Thanks!
private void EnsureMaterialAndAssignToLayer(RhinoDoc doc, DisplayMaterial sourceDisplayMaterial, string materialName, bool shouldUpdate)
    RenderMaterial customMaterial = null;
    foreach (var mat in doc.RenderMaterials)
        if (mat.Name.Equals(materialName, StringComparison.OrdinalIgnoreCase))
            customMaterial = mat;
            break;
    if (customMaterial == null)
        Material basicMat = new Material();
        basicMat.Name = materialName;
        if (sourceDisplayMaterial != null)
            basicMat.DiffuseColor = sourceDisplayMaterial.Diffuse;
            basicMat.Transparency = sourceDisplayMaterial.Transparency;
            var texture = sourceDisplayMaterial.GetBitmapTexture(true);
            if (texture != null)
                basicMat.SetTexture(texture, TextureType.Bitmap);
            var transparencyTexture = sourceDisplayMaterial.GetTransparencyTexture(true);
            if (transparencyTexture != null)
                basicMat.SetTexture(transparencyTexture, TextureType.Transparency);
        // This is the standard way to create a RenderMaterial that can be assigned.
        customMaterial = RenderMaterial.FromMaterial(basicMat, doc);
        if (customMaterial != null)
            // Double-check name assignment (sometimes FromMaterial might not copy it perfectly)
            customMaterial.Name = materialName;
            // Add the newly created render material to the document's material table
            if (!doc.RenderMaterials.Add(customMaterial))
                AddRuntimeMessage(GH_RuntimeMessageLevel.Warning, $"Failed to add new render material '{materialName}' to the document.");
                customMaterial = null; // Indicate failure
            // At this point, if successful, grassRenderMaterial.Id is valid and it's in the doc.
        else
            AddRuntimeMessage(GH_RuntimeMessageLevel.Warning, "Failed to create render material from basic material properties.");
    else if (shouldUpdate)
        //how to update or modify RenderMaterial??
    // 3. Assign the found or created material to the layer
    if (customMaterial != null && _targetLayerIndex >= 0)
        Layer targetLayer = doc.Layers.FindIndex(_targetLayerIndex);
        if (targetLayer != null)
            // Set the render material id for the layer
            targetLayer.RenderMaterial = customMaterial;
            //targetLayer.RenderMaterialIndex = grassRenderMaterial.Id;
            // Commit the changes to the layer back to the document
            if (!doc.Layers.Modify(targetLayer, _targetLayerIndex, true)) // true means 'quiet'
                AddRuntimeMessage(GH_RuntimeMessageLevel.Warning, $"Failed to assign material '{materialName}' to layer '{targetLayer.Name}'.");
            //else
            //    // Optional: Success message
            //    // AddRuntimeMessage(GH_RuntimeMessageLevel.Remark, $"Assigned material '{materialName}' to layer '{targetLayer.Name}'.");
        else
            AddRuntimeMessage(GH_RuntimeMessageLevel.Warning, $"Could not find layer with index {_targetLayerIndex} to assign material.");
    else if (_targetLayerIndex < 0)
        AddRuntimeMessage(GH_RuntimeMessageLevel.Error, "Cannot assign material: Target layer index is invalid.");
existingRenderMaterial.Replace(NewRenderMaterial)
https://developer.rhino3d.com/api/rhinocommon/rhino.render.rendercontent/replace#(rendercontent)
Thanks, bro!!
