How to UNINSTALL VISUALARQ 2?
Tried using the system uninstall a program, didn’t work.
If you are using windows 10 make sure use the task manager and the same varq.msi to Uninstall . Task manager … file … New task . Check on create as administrator … browse where the varq.msi …change programs to all files … select varq.msi … ok.
I’m using windows 7 and it should be a lot easier than that.
Okay use the varq installer the remove
Just had the same problem.
In my case the plugin was actually uninstalled but the toolbars were left behind. To solve the problem go to C:\Users\UserName\AppData\Roaming\McNeel\Rhinoceros\5.0\UI and delete the visualARQ rui and its backup. Run Rhino and check the UI folder again.
