How to transform a solid with some lines
hello,
I try to transform my solid with the cross just under the solid like the picture attached. I don’t understand how I can do. If someone can help me I will be very enjoy.
thanks a lot in advance
deformation.3dm (2.5 MB)
Hello - does this file help at all?
deformation_Maybe.3dm (215.1 KB)
hello thanks but on the back side I need that is not a plane form. I need that the other side is the same at the front side.
Could you please if you have time explain the difference steps?
thanks a lot ,
best,
Nicolas
please find here a test I made but I don’t arrive to close the corner…
thanks a lot,
Nicolasplat.3dm (2.6 MB)
@pascal Golay
wich tool are you use to make a corner chamfer because when I do this tool I have this (please look this picture)
