How to to calculate view factor
Hi.
I want to calculate a simple view factor.
In other words, I fire rays from a certain point and want to know what the object the ray hits first.
However, if you use “Mesh | Ray”, each object is calculated separately, so the ray will pass through it. If you use “ShootRay”, you only know the coordinates.
Is there a good way to do it?
Thanks.
view_factor.gh (24.6 KB)
Isn’t that exactly what “IsoVist Ray” component does?
You need a specific solution inside python?
Is this what you want?
view_factor_re.gh (26.9 KB)
Thanks for the fast reply!
It is exactly what I was looking for.
Thank you for attaching an easy-to-understand sample.
It seems that we are finally able to proceed to the next step.
