How to test at runtime if my dll is running inside Rhino or not?
#1
How can I test at runtime if my dll is inside Rhino or not.
Basically I want to know if I can call into the unsafeNativeMethods (like most are) of RhinoCommon.dll or not.
(Menno Deij - van Rijswijk) #2
I think that
bool Rhino.Runtime.HostUtils.RunningInRhino
should be used for this.
Unfortunately, if I run this outside Rhino it still returns true. @stevebaer may know why this is (possible bug?)
A better test is (I just found this)
if (null == RhinoApp.MainApplicationWindow)
    Console.WriteLine("Not running in Rhino");
else
    Console.WriteLine("Running in Rhino");
#3
I do it via exception handeling now in f#:
let isRhinoRunning =
    try
        Rhino.RhinoDoc.ActiveDoc |> ignore // this line will fail if not in RH
        true
    with
        |e -> false
(Menno Deij - van Rijswijk) #4
It depends which type of exception is thrown. An AccessViolationException can lead to instabilities and may not be caught.
#5
works correctly for me in F# Interactive in VS.
trying to access the ActiveDoc throws
System.BadImageFormatException
or
System.TypeInitializationException
(Steve Baer) #6
How are you testing this? RunningInRhino is the correct property to check and it should be returning false when not inside the Rhino process.
(Menno Deij - van Rijswijk) #7
I copy RhinoCommon and its 8 dependencies (rhcommon_c.dll, Rhino.exe, etc.) to my output folder and run it through NUnit integrated in VS2010 by ReSharper. (I hope this make sense :smile:)
Most of the RhinoCommon functionality is available, but some give AccessViolationException.
Unit testing plug-in code with NUnit
(Steve Baer) #8
Ok; I’ll have to look into this a bit more to see how on earth this is returning true in that case.
