Can we taper/shrink a poly-surface? I have a fork, and the ends of the fork are a little wider than I want them to be; therefore I would like to taper the ends of the fork. What is the best way to do this?
Thanks.
Thanks.
CageEdit in some form should help here -exactly how you set up the cage depends on the object and what you want to do, so it may take some experimentation.
