How to taper an open SubD
rose pieces.3dm (9.3 MB)
Can anyone tell me how to taper this so the bottom is about 8" and the top is 3-4" and make it a solid object for 3d printing?
you can cage edit these using a cylinder.
once you have them edited to the size you want, use the offset subd to make them have some thickness.
then mesh, and export the mesh as stl, or obj to your printer.
if you are not familiar with cage edit, start on page 199 in the level 2 manual pdf in help>learn rhino>tutorials and samples> level 2 pdf.
