How to swap stairs direction
I am trying to swap the direction of my stairs so it looks something like this (instead of what I have now):
I also want everything to stay very parametric!
I’ve tried everything and it keeps ruining my script and messing it up. Any tips on how to do this would be greatly appreciated!
FinalBuilding - Copy.gh (75.3 KB)
Looking back at what I wanted, it doesn’t make sense I apologize. I think, what would make more sense is to have them be connected and swirl up, but have a landing for each floor…
but I am unsure how to do this in grasshopper with my existing script…any ideas? Also thank you so much for your response!
My idea.
Fix the scales.
Thank you! I also tried twisting it around like this and just added landings and cut a circle through the floor plates:
However, now I am having trouble cutting through, because I used the trim solid instead of solid difference because solid difference doesn’t seem to be working. However, trim solid creates a gap in between the cut:
Honestly, playing around with it but not quite sure what’s fitting…will definately check out what you’ve sent! Thank you so much. Any thoughts on how to fix this solid difference though?
I attach the definition with my final result internalized.
FinalBuilding - Copy c.gh (605.7 KB)
If it can be useful, with this definition you get a closed brep of the entire building.
I redid the stairs. (blue group)
FinalBuilding - Copy d.gh (286.1 KB)
Thank you so much! Quick question, how do I stop it from being a wireframe?
